Understand how aluminum and steel behave under a plasma arc, how to set up for clean edges, and where Cutmaster 30+, 50+, and 70+ fit different jobs.
Plasma cutting combines speed, precision, and versatility in a way few processes can match. With a single machine, you can switch between aluminum, mild steel, stainless, and more. For thin and medium sections, plasma consistently outpaces oxy‑fuel and most mechanical processes, especially where pierces and curved profiles are required.
A narrow kerf and smaller heat‑affected zone help preserve dimensional accuracy and reduce distortion. That means less time on edge prep before welding and fewer scrap parts from overheating. The ability to pierce directly into plate streamlines workflows in fabrication, repair, and field work alike.
Aluminum’s high thermal conductivity spreads heat rapidly away from the cut. If travel speed is too slow, excess heat accumulates and the molten metal can cling to the edge. Operators sometimes interpret this as a machine or consumable issue when it’s often a matter of speed, standoff, and air quality.
Start with a faster travel speed than you would use for steel of the same thickness. Match amperage carefully and maintain a consistent standoff of roughly 1/8 inch (3 mm) unless using a drag shield designed for contact. Clean, dry air is non‑negotiable: moisture or oil aerosol in the air line destabilizes the arc and can create a porous, rough edge.
On thin sheet, plasma can produce clean edges with minimal cleanup, especially with a straightedge or circle guide. On thicker plate (≥ 12 mm), a higher‑output unit with strong arc density — such as a 70‑amp class machine — helps maintain penetration and edge quality. Expect some dross on the bottom of thicker aluminum; the goal is to minimize it with speed and standoff, then remove the small remainder quickly during finishing.Operator checklist for aluminum: increase travel speed, verify dry air, keep standoff steady, and replace nozzles before visible ovaling. These steps have the biggest impact on edge appearance.
Mild steel behaves predictably under a plasma arc, allowing fast, square cuts with little distortion. Plasma excels on thin‑to‑medium sections up to about 25 mm, with consistent cut faces and minimal bottom dross when the travel speed is correct. On thin sheet, the narrow kerf makes intricate shapes and tight nesting practical, improving material utilization.
Set amperage to match thickness and use the correct nozzle size for that current. Watch the stream of sparks: when they eject straight down under the cut, speed is generally correct. If sparks trail backward, you are too slow and will see increased dross; if they spray forward, you may be moving too fast to fully sever the material.
For stainless steel, the same principles apply, but you may observe more discoloration; keeping the arc stable with good grounding and clean, dry gas helps reduce post‑cut finishing time.
Consistency comes from setup discipline as much as it does from machine capability. Build the following checks into your routine and you’ll see immediate improvements in both aluminum and steel:
The Thermal Dynamics Cutmaster lineup covers portable field tasks through heavier shop work and entry‑level CNC integration. Choose the output class that matches your most common thickness range, then scale up for occasional heavier jobs as needed.
At‑a‑glance selection guide. Always verify exact specs in the product manual.
Plasma cutting produces intense light, heat, and fumes. Wear flame‑resistant clothing and gloves, and use a helmet with the appropriate shade (often #5–#9 for handheld plasma; consult your safety guidelines). Provide adequate ventilation or fume extraction for indoor work. Aluminum dust is combustible, and steel fumes can be hazardous with prolonged exposure. Secure workpieces to prevent shifting, and inspect power leads, work clamp, air hoses, and consumables before each shift.
