Many crucial industries including oil and gas, biopharma, and food and beverage, rely on the elaborate networks of pipe or tube systems to ensure a continuous supply of material while enduring high temperature and pressure conditions. The demand for high standards from the pipe and tube system means their fabrication has to be done precisely and consistently to uphold the metallurgical properties of the high-quality metal being used.
Metal Inert Gas (MIG) and Tungsten Inert Gas (TIG) have been considered the most popular and reliable welding processes for many metal fabrication projects. However, when the choice has to be made between TIG vs. MIG welding in pipe and tube fabrication, operators have many project-specific requirements to consider, such as the material type, joint design, and weld quality.
So today, we will compare TIG vs. MIG welding in pipe and tubes and explore the advantages of using each welding process in delivering quality results.
Joining pipe and tube sections may seem like a simple task. Still, it requires intricate attention to detail and precision in selecting welding parameters, such as heat input, travel speed, electrode angle, shielding gas, and many others.
The implementation of these critical parameters can be done reliably with the use of welding processes like TIG and MIG. These arc welding processes are known for their ability to produce welds with minimal defects, but they may have differences in approach.
TIG or Gas Tungsten Arc Welding (GTAW) uses non-consumable electrodes to weld metals. When pipe and tube welding, TIG provides the advantage of precision weld parameter control. The ability to adjust the heat input, gas flow rate, and weld speed reduce the chances of weld overheating or underheating, providing adequate penetration to form a strong weld. This control is also why TIG is preferred for welding thin-wall pipes or tubes to avoid issues like burn-through or distortion.
MIG or Gas Metal Arc Welding (GMAW) uses consumable wire electrodes and shielding gas to create an arc. The process is faster and more efficient, making it suitable for large-volume production. The weld produced is usually strong and durable but not devoid of defects, given the lack of precision control. Thus, it is unsuitable for welding thin metals as a lack of heat control may lead to pipes and tubes being prone to issues like distortion and burn-through.
The table below shows the general comparison of TIG vs. MIG welding.
Operators can select between TIG vs. MIG welding in pipe and tube by comparing the advantages and disadvantages of each process based on the table above to suit the quality and productivity needs required for the project.
Pipe and tube welding is challenging since each welding application comes with a different set of requirements. For example, some applications may require the use of thick pipes, while others may require the use of thin tubes with corrosion-resistance properties. Each such application requires a different set of criteria to select the welding process. Additionally, the pipe and tube welds also have to pass the different sets of industrial quality standards.
Choosing the best method between TIG and MIG welding processes ensures reliability when fabricating pipes and tubes while achieving productivity goals. Things to consider include:
Both TIG and MIG welding processes are excellent choices for creating high-quality welds, each with its unique advantages. The choice will ultimately depend on the quality and productivity need that your application requires. For a more complex and quality-strict weld, TIG can be the go-to process, while MIG is for faster and more efficient needs. An effective comparison between TIG vs. MIG welding in pipe and tube applications will help you select the process needed to achieve the specifications required to meet industrial standards.
