Pilot arc technology is one of the most important features in modern plasma cutters. It ensures reliable arc starts, reduces consumable wear, and makes cutting coated or perforated materials easier. In this guide, we’ll explain how it works, why it matters, and how it’s applied in Thermal Dynamics Cutmaster systems.
A pilot arc is a low-energy, pre-cutting arc formed inside the torch before the main cutting arc strikes the workpiece. It ionizes the gas stream, creating a conductive plasma path that can then transfer to the grounded metal without the torch tip touching the work.
This differs from contact-start systems, where the torch must physically touch the material to initiate a cut—often causing nozzle damage, inconsistent starts on rusty or painted surfaces, and difficulty on perforated or expanded metals. Pilot arc enables touch-free arc initiation that works consistently across varied conditions.
This entire sequence takes milliseconds, but it’s the difference between smooth, immediate starts and frustrating misfires.
Pilot arc generally extends consumable life, but proactive maintenance still matters:
Thermal Dynamics Cutmaster machines pair pilot arc starts with proven torch design for reliable performance across materials and thicknesses:
Combined with the SL60QD™ 1Torch® consumables and gas path geometry, these systems provide stable, clean starts and dependable transfers—even on painted or perforated materials.
Ready to power up your plasma cutting with Thermal Dynamics? Compare Cutmaster models and find the right machine for your needs.
