In spite of the name, welding power supplies are not typically the source of electrical power for arc welding. Instead, they are power inverters and transformers that work by converting the electrical power from a building’s power or a generator into a current type that is suitable for the welding application being performed. Inverters using an insulated-gate bipolar transistor (IGBT) technology are more common in newer welding power supply types, while transformers are usually found in older power supplies. In welding processes like shielded metal arc welding (SMAW) and gas tungsten arc welding (GTAW) for welding pipe, welding power supply types commonly combine power generation, inverters, and a few extra controls needed to modulate the current.
The choice of welding power supply is what makes the difference between a slaggy lump of melted metal and a quality weld. For this reason, it’s critical when choosing a welding power supply type that their nuances and the elements they control are understood.
An arc is essentially a short in between the positive and negative sides of a circuit. Usually, it involves creating an air gap between conductive materials that is small enough for the voltage in the circuit to jump across. It is possible to create an arc in nearly any electrical circuit, such as when you reach for a doorknob and get shocked on a dry day. Arc welding simply involves sustaining this arc. A welding power supply is what enables the controlled conditions to create smooth, continuous beads of structurally sound metals.
At a minimum, a welding power supply type will allow the welder control over the following elements of current flow:
Welding power supply types are defined by how they modulate electrical currents, and what arc welding process is best supported by this modulation:
There are many general-purpose welding machines that offer the choice between welding using AC or DC current. DC is a better welding option for steel and other ferrous metals, while AC current is almost a requirement for welding aluminum. Alternating current breaks up the oxides that form on aluminum welds and allows the metal to be welded at lower amperages than would be possible with DC. This is a consideration in other metals and alloys that share a similar oxidation profile with aluminum, and that also need the oxide layer broken up before welding can commence. AC welding is also used to speed up material deposition and welding overall in more typical steel and steel alloys.
In GTAW processes, however, DC pulsed current welding power supply types are used almost exclusively (AC welding power supplies are occasionally used for GTAW welding aluminum). This is because GTAW is typically used for very high-specification welds and pulsed current welding results in a much purer weld, with increased penetration and far less heat distortion than with non-pulsed welding.
Welding aluminum with GTAW requires an AC power supply to break up the oxides that form on the surface when the metal is heated. However, in nearly all other GTAW welding applications, DC with pulsed current is superior. It allows greater control of bead formation and heat input into the weld. Given the sort of high-spec welding that GTAW is used for, a DC pulse-type welding power supply is generally preferable.
DC pulse welding power supplies are preferred over other welding power supply types for challenging stainless steel welding.
Stainless steel is notorious for how difficult it is to weld and how easily it warps during welding. GTAW already has a low heat input compared to other types of arc welding, and DC pulsed current lowers this heat input still further while simultaneously increasing the heat focused on the weld. This deepens penetration while narrowing heat-affected zones. As a result, DC pulse welding power supplies are preferred over other welding power supply types for challenging stainless steel welding like welding thin-walled stainless steel tube. The ability to narrowly focus heat also makes DC pulse welding the best way to weld Inconel® and other high-specification austenitic metals. For challenging pipe and tube welds, the best approach is orbital GTAW backed by a DC pulse welding power supply.
Pipe and tube welds are challenging due to the geometry of working around a cylinder. Orbital welding offloads the movement of the electrode around the workpiece to an automated system, removing the challenge for the welder of having to position themselves as they work around the circumference of the piece.
Higher amperage welding power supply types are made for welding pipe and other thick-walled materials and support welding accessories such as wire feed weld heads.
The best welding power supply types for orbital GTAW welding of steel, stainless steel, exotic alloys like Inconel or Monel, or even titanium, are DC pulse power supplies. Within this category, the choice of power supply will depend on the thickness of the materials being welded. Fusion welding power supplies are made for thin-walled materials and are available in both bench-mounted and more portable forms. Higher amperage welding power supply types are made for welding pipe and other thick-walled materials and support welding accessories such as wire feed weld heads. These work in tandem with power supplies designed for hot wire welding that speed up deposition.
The choice of a welding power supply type should be made to support the material and arc welding process being used. In particular, any welding power supply type used for high-specification welding like GTAW orbital welding should come from a manufacturer with extensive experience in the design of orbital welding power supplies and familiarity with the ins and outs of the orbital welding process.
