Welding a large bore pipe is a big job. Big bore piping is generally defined as having an interior diameter of two inches—approximately five centimeters—or more, but pipes are most often referred to as “large bore” when they are 30 inches in interior diameter or larger. This is about the diameter at which welders can be reasonably expected to crawl inside the pipe, and many, though not all, pipes of this size may need inside diameter welding in order to meet welding production specifications. Whether or not this is the case, it is clear that big bore pipe welding requires a significant amount of welding for each joint. The most efficient way to produce welds of length, depth, and size quickly and reliably is with the use of an automated orbital welding machine.
Welding pipes with walls thinner than an eighth of an inch (about three millimeters) is straightforward. Even large bore pipes with walls this thin can be welded in a single pass. However, when the thickness of the pipe wall is higher, welding a pipe joint becomes a process requiring multiple passes around a large circumference. Orbital pipe welding brings several advantages to the complex task of big bore pipe welding:
The advantages of the orbital welding process result in a weld that is much more consistent–and therefore higher quality–than a manually performed weld. Due to the diameters involved in welding large bore pipes, the time, labor, and cost advantages tend to be exponentially magnified. On truly big bore pipe welding projects, orbital welding should be the first welding process considered to ensure the job is completed as scheduled.
There are numerous types of manual arc welding processes, but fewer types of orbital welding, which tend to be limited to processes using a wire feed, inert gas shielding, or a combination of both.
Three types of orbital welding are well suited for use on big bore pipes:
GTAW produces no sparks or spatter and makes the neatest and cleanest welds of the three processes above. This also typically translates into greater strength and durability over time for the weld. Choosing GTAW orbital, rather than manual, welding allows a project to take advantage of the benefits of GTAW, such as strength and consistency, without the inefficiency of the manual process.
As well as being more efficient, GTAW orbital welding also offers a more manageable learning curve than manual TIG welding and makes the welding process far less taxing physically. An orbital GTAW weld head, which includes the torch, mounts to a track that encompasses the entire exterior or interior circumference of the pipe being welded. There is effectively no upper limit to the size of pipe that can be welded using a high-quality large diameter pipe weld head. Once a guide ring is mounted to the pipe and the controller is programmed, then the welding process is simply a matter of letting the weld head follow its preprogrammed routine for each pass. The orbital welding machine–rather than a human welder–is responsible for keeping the electrode steady and the fill material in alignment with the electrode, and maintaining the proper angle of the assembly relative to the weld.
Orbital welding allows GTAW welds to be produced consistently and precisely without the enormous effort involved in finding or training highly skilled and experienced manual welders. Orbital GTAW also brings the speed of automation to the job site, allowing GTAW welds to be produced with machine-like reliability, efficiency, and precision. GTAW orbital welding delivers cost-saving quality, ease of use, and speed to each joint of a big bore pipe welding project.
Learn more about how orbital welding is shaping industries worldwide in our full guide: Orbital Welding Technology, Applications, and Industries.
