Autogenous orbital GTAW, or gas tungsten arc welding, is a highly specialized process that uses an automated welding system to join two pieces of metal without the need for filler metal. The process offers a high level of control and is popular in industries that need the highest quality and purity of welds, like semiconductor manufacturing, aerospace, and pharmaceuticals.
Today we will outline the basics of autogenous orbital GTAW, exploring the process and discussing the benefits and applications.
Autogenous welding is a process in which no filler material is needed to join two pieces of metal. Instead, the base metal on each side of the join is fused together to create the weld. Orbital welding uses an automatic weld head that articulates a tungsten electrode through a half (180-degree) or full (360-degree) rotation around the stationary welded material. Orbital welding was designed to reduce operator error in GTAW welding. Finally, GTAW, which is also known as tungsten inert gas (TIG) welding, is a process that produces a weld with a non-consumable tungsten electrode. GTAW forms an arc between a pointed tungsten electrode and the welded material using an inert gas shield (argon or helium) without melting the electrode.
Autogenous orbital GTAW produces strong, high-quality welds for piping units up to 6 inches (or 15.24 centimeters) in diameter and with a wall thickness of under 3 millimeters. The automatic weld head, and the elimination of filler material, simplifies the welding process while providing a high level of control and precision.
Some of the benefits of autogenous orbital GTAW include:
Autogenous orbital GTAW is a cost-effective technique for welding small-diameter, thin-walled pipes or tubing because it requires fewer consumable materials and less manual effort to produce a large quantity of strong, accurate, high-quality welds.
Autogenous orbital GTAW is used for circular joins in pipes, tubes, and fittings, typically (but not always) composed of 316 SS (stainless steel). It’s primarily used in industries requiring high purity, such as semiconductor fabrication, pharmaceutical, and medical applications. The repeatability and control provided by autogenous orbital GTAW also make it useful in highly regulated industries that require robust recordkeeping. In addition, orbital GTAW can be used in spaces where it’s difficult or even impossible for human operators to complete a manual weld. Some examples of jobs that benefit from autogenous orbital GTAW include piping for fluid systems in wastewater treatment and semiconductor processing, as well as fuel, coolant, and hydraulic lines for aircraft, industrial equipment, and automobiles.
