In welding, precision and efficiency are key factors that influence the quality and durability of the output. Among the different welding techniques, welders prefer gas tungsten arc welding (GTAW) and plasma arc welding (GTAW-P or PAW) to ensure accuracy and control in the fusion process. The similarities between the two techniques, mostly based upon the use of non-consumable electrodes and inert shielding, are the base on which these approaches produce clean and quality welds. However, some significant differences between each welding approach make them unique for varying types of welding applications.
So today, we will compare GTAW vs. GTAW-P(PAW) and explore the scenarios where each approach is appropriate.
In the sections below, we will take a deep dive into each and explore the similarities and differences in GTAW vs. GTAW-P.
GTAW, also known as tungsten inert gas (TIG), is a welding process that utilizes a non-consumable tungsten electrode to initiate an arc with the workpiece. The arc generates intense heat and melts the base metal to create fusion. The inert shielding gas provides a protective environment to keep the contaminants away from the weld pool, facilitating the creation of a clean weld joint.
One key feature of the GTAW process is its exceptional control of weld parameters. Welders can adjust the parameters such as the current, voltage, travel speed, gas flow rate, etc., to ensure precise and consistent weld results free of all major and minor weld defects. Other benefits of opting for the GTAW process include:
Plasma Arc Welding, PAW or GTAW-P, is a welding process that uses a highly concentrated, high-temperature plasma arc to melt and join the workpiece. Like GTAW, the process involves selecting electrodes and shielding gas. The next step is the generation of the plasma arc, which is done by passing a high-velocity gas, which typically includes argon or a mixture of argon and hydrogen, through a narrow nozzle opening. The temperature of the plasma arc may reach temperatures as high as 30,000°F. When such high-temperature plasma is directed toward the metal, it melts the workpiece to create a weld joint.
A few key features of the GTAW-P process include:
The table below summarizes the comparison between the GTAW vs. GTAW-P(PAW) welding processes.
Despite the differences, both welding approaches produce high-quality and precise weld results when welding complex joint designs.
The factors mentioned above are the leading facets that should be considered before selecting the best welding approach. Generally, the following scenarios should be considered.
When it comes to precision welding, both GTAW and GTAW-P offer their own unique advantages. While GTAW excels in terms of weld quality, versatility, and compatibility with different metals, GTAW-P is the perfect option if you are looking for concentrated heat input and faster welding.
Before deciding the best option between GTAW vs. GTAW-P(PAW), it is essential to consider the complexity of the process and quality requirements for the industry. It is always a good idea to consult expert welding professionals and the related industry standards. With informed decisions, you are sure to achieve high-quality and precise results that meet your project’s specifications.
