Automated orbital welding offers many advantages over manually welding piping systems. Consistency, higher quality, lower overall cost, and faster project completion are just a few reasons to employ an orbital welding approach. Additionally, orbital welding enables the operator to work at a safe distance from the weld puddle and any potentially toxic fumes. To meet your project needs, the industry leader in orbital welding equipment, Arc Machines Inc. (AMI), offers you a choice of weld head types for external or outer diameter welding: open and closed configurations.
AMI’s open and closed orbital weld heads both deliver high-quality weld results. However, there are times when one is preferable. Although closed weld heads are compact and reduce exposure to shielding gases, open weld heads can be used in much tighter environments. For example, open weld heads offer advantages when welding onsite and angular movement is limited or pipes are tightly arranged.
When using AMI’s open weld heads, you can expect superior performance and features as listed below for the Model 79 series.
AMI offers several options for open weld heads, as shown below.
To maximize performance for exterior diameter welding, you need the right electrode. AMI offers tungsten electrodes that match or exceed any in the industry.
AMI provides ground and polished electrodes that will meet your open weld head orbital project needs for industries including food processing, pharmaceuticals, energy generation, and other high-spec projects.
As shown above, AMI tungsten electrodes have varied use cases; however, all can be used for consistent, high-quality TIG welding. Additional equipment, though, is necessary to complete and optimize your open weld head orbital system.
In addition to industry-leading open weld heads and electrodes, AMI also delivers advanced equipment as listed below.
If your application calls for open weld head orbital diameter welding, look to the experts at AMI for the best equipment to suit your project needs.
Learn more about how orbital welding is shaping industries worldwide in our full guide: Orbital Welding Technology, Applications, and Industries.
