The workspace around a handheld laser welding system presents hazards that extend well beyond the immediate weld point. Laser beams and their reflections can travel across a room, pass through doorways and injure people who are not involved in the welding operation. Establishing a properly controlled laser welding workspace — before the system is powered on for the first time — is one of the most important safety steps any organisation can take. This guide covers the workspace setup requirements for handheld laser welding systems.
Every laser welding operation, including demonstrations, must have a designated Laser Controlled Area (LCA). The LCA is the physical zone within which the laser operates and within which laser safety controls are enforced. Anyone entering the LCA is subject to the full PPE and safety requirements that apply to the operating wavelength and power class.
An LCA should incorporate:
Laser warning signs must be posted throughout the controlled area, with particular attention to all entrances and exits. Requirements include:
Physical barriers serve two functions: preventing the laser beam or its reflections from leaving the LCA, and stopping unauthorised personnel from entering the hazard zone.
Modern laser welding systems incorporate several layers of safety interlocks designed to prevent accidental or unauthorised laser emission. These must be verified before operation and must never be bypassed:
Ensure all machine safety interlocks are functioning correctly before each operating session. Any interlock fault must be rectified before the system is used. Never bypass interlocks or safety mechanisms under any circumstances.
Laser welding generates fumes and gases from the base material, filler wire (if used), coatings, paints and chemical reactions in the weld pool. These must be extracted from the LCA to protect operators and bystanders.
Before starting each laser welding session, complete the following checks:
Explore more ESAB University guides covering laser welding processes, protective equipment, workplace safety, and hazard prevention.
