In conversation, it’s sometimes difficult to tell whether the word “welder” refers to a machine or its operator. However, it’s obvious whether a weld bead was laid down by a human or a machine. Automated welding has a level of consistency that even master manual welders can’t match. With machine welds, it’s often impossible to discern individual weld beads. This is especially true in pipe welding, where the nature of the material means that a manual welder must start and stop to change positions. Automated TIG orbital welding has the advantage of being continuous, and given the skill and quality challenges of manual pipe and tube welding, it’s clear that orbital welding is underutilized. Still, there are advantages and disadvantages to orbital welding, and it’s a good idea for any project manager in the development phase of a pipe or tube welding project to consider both before making a decision.
In order to understand the advantages of orbital welding, it is necessary to understand how manual pipe welding is usually performed. It is close to impossible for a manual welder to weld the entire circumference of a pipe in a single uninterrupted pass. Instead, the circumference of a pipe is divided up into quarters, and each pass is completed one quarter at a time. This creates inconsistencies as the arc is stopped and started again. Changing the temperature of the fill material and pipe from hot to cold to hot again multiple times affects the degree of penetration and fusion. The welder must also change position for each quarter of the circumference. Two of those quarters will be in the overhead position, which is widely known as a tiring and difficult welding position.
In orbital welding, the operator mounts the weld head by clamping it to the pipe directly (like a set of vice grips) or by using a guide ring fitted to the pipe. With both methods, the weld head moves around a typically stationary pipe. The operator monitors the weld in case an intervention is needed. Orbital welding offers the following advantages compared to traditional manual pipe welding:
The result of these advantages is the precision, predictability, quality, and consistency that makes a machine weld so immediately identifiable. And this is true of more than just the visual aspect of a weld. Once a weld procedure from an automated orbital system has been qualified for the structural and mechanical characteristics required by the project, the system will be able to reproduce that quality consistently and be able maintain the tolerances specified in the weld schedule. Any application involving high pressures, corrosive substances, or the need to withstand constant vibrations would see major benefits using an automated orbital welding system.
The advantages of orbital welding and other automated welding processes are so manifest and apply to so many applications that from an engineering standpoint it is surprising that manual welding is still widespread. However, there are some disadvantages to the purchasing, setup, maintenance, and operation of orbital and other automated welding machines.
The disadvantages of orbital welding have little to do with the welds produced by an orbital welding machine, which are precise and repeatable as long as all variables are taken into consideration. Instead, they have to do with orbital welding being a relatively rare and niche process. As a result, barriers to adopting orbital welding may arise in the following areas:
Many of these disadvantages are more apparent in smaller projects, where the costs of equipment, training, and setup time may not be worth it. However, in large, repetitive pipe welding projects, orbital welding’s advantages quickly outweigh its disadvantages. The key to getting the most out of an orbital welding setup is to choose an experienced orbital welding vendor that offers training classes on specific equipment as well as reliable repair, replacement, and maintenance services.
Learn more about how orbital welding is shaping industries worldwide in our full guide: Orbital Welding Technology, Applications, and Industries.
